Removing side view mirror base
davidrbroder62
I am trying to replace the driver side sideview mirror of my 1996 Z3. The bolts are completely corroded and have no heads on them. I was told to drill them out. In attempting to do that I have destroyed several drill bits which have broken off in the attempt.
The base is not moving, I dont want to damage the door but am at a loss.
Anyone else try to attempt this? What did YOU do to accomplish this task?
I can’t help, but am sympathetic. My bolt heads were not too badly corroded.
IainP
Cobalt drill bits from Toolstation, 40442 is a set of six, but you’ll likely need an 8mm as well. Use a little lube and don’t use too high a speed, they’ll go through the head like butter.
You could try getting a reverse (left handed) drill bit..as long as you have a drill that will also go in reverse. I promise it’s a thing..it’s not tartan paint or anything like that ;)
Drilling the bolt head off will get the mirror base off but then you'll still have the bolt shaft/thread stuck in the door. Not sure how easy that will be to get out. I can't remember how the captive nut thread is attached to the door panel.
I think I'd have tried an extractor.
Z3 1.9 M44 Roadster Z3 2.8 Roadster
worst case… you drill out the bolts and damage the thread in the door.
but then just drill out and insert a Rivnut… ( I have loads of different sizes if you need any. )
