Z3M Fuel Filter
Any of you Z3M owners changed your filters? My M filter is for the plastic push connectors, as in the diagram not rubber pipe push on with jubilee clips as in the photo, trouble is I can't source the right filter. I could cut the pipes and just use jubilee's but would rather not, I had the same issue with the pervious M too so never changed it. Any advice on where to get one other than stealers.
Bump
Hi Lee, yeh the pipe ends are fine just trying to find the correct filter for them to snap on to, the one you linked is the push on and jubilee type, looks like the best option to cut the clips off and just modify.
  • Agree
Yes, you need to cut the plastic pipes on both ends and install some 8mm fuel hose with Jubilee clips.
It means you will lose some concours points, but you will have filtered fuel :ymdevil: .
